Has anyone tried this?
Old 10-26-2004, 04:51 PM
drags's Avatar
Default Has anyone tried this?
Has anyone tried putting a brick of dry ice in the airbox next to the filter?
What happens?
or what would happen? - for the technical gurus
Old 10-26-2004, 05:13 PM
S2k_fever's Avatar
Not a very good idea as CO2 will try to work against the engine's combustion and your car will want to choke.
Old 10-26-2004, 05:26 PM
xviper's Avatar
Dry Ice = Carbon Dioxide (CO2)
Just as they use CO2 to kill pigs in a slaughter house (suffication), it will also kill your engine.
Old 10-27-2004, 08:34 AM
Elistan's Avatar
Like they said, your car won't run.
You want to put the dry ice ON the airbox. (Intake manifold as well.)
Old 10-27-2004, 09:58 AM
TubeDriver's Avatar
Add ice cream and a banana and you would have a really cold banana split?
Old 10-27-2004, 10:49 AM
hpark's Avatar
What happens?
what the
Old 10-27-2004, 10:55 AM
S2000RAT's Avatar
Is this fooooor real?
Old 10-27-2004, 10:56 AM
mikegarrison's Avatar
I think you fail to understand the amount of airflow going through that engine and the rate at which heat can be pulled out of it from the sides.
Old 10-27-2004, 04:21 PM
alexf20c's Avatar
Well, the computer would read the extra oxygen (unmetered by MAP) as a lean condition, and adjust the fuel trim to accommodate. It would overcompensate and dump fuel into the cylinders, and the overly rich AFR would cool the combustion chamber. So, if his goal was to cool the incoming air and/or the engine, the dry ice mod would work.
I've also read great things about the Tornado airbox mod, as seen on TV. It would help counter the shitty fuel mileage caused by the unnecessarily rich air/fuel mixture.
Old 10-27-2004, 04:46 PM
xviper's Avatar
Quick Reply: Has anyone tried this?
