Has anyone rebuilt their clutch master cylinder?
yesssss i am the friend ![cool.gif](https://www.s2ki.com/forums/images/smilies/cool.gif)
since Omni claims that the brake fluid eats up their seals, i think using aftermarket brake fluid over time is what's causing the MC to go bad. i don't see how a little dirt between the seals and the metal parts of the MC can cause a significant leak![th_dontknow.gif](https://www.s2ki.com/forums/images/smilies/th_dontknow.gif)
btw i need my MC back when you're finished, or $20.
oh you didn't say the walls were scored before. so you think the grime between the piston and the walls there scored them? if so then how would you rebuild it fully? the walls would still be scored and cause leaks ![th_dontknow.gif](https://www.s2ki.com/forums/images/smilies/th_dontknow.gif)
and i cant put this one on. i need my car back asap and i get out of school at 7:30pm. so i'm going to jsut put the new one on and be done with it. sorry, man.
I don't have a clue whether the other fluids led to the leak or not. However I do think the fluid might have something to do with the weird clutch pedal feel I have right now. first time I used the oem fluid and it felt fine. the next two times i bled with valvoline synpower and the pedal feel is not consistant. sometimes it's heavy and sometimes it's light. i don't think mine is leaking though. just feels weird. have to check tomorrow.
I'm going to tear apart both the master cylinder and slave cylinder and give both a thorough cleaning before changing my clutch next week and post my results.
ktwenty
11-09-2014 12:23 PM
stack
11-07-2010 07:44 AM
