Has anyone here removed and installed the DBW
#21
Originally Posted by 2QYK4U,Jul 17 2007, 05:06 PM
So, your scan tool cannot perform the same functions as the HDS.
#22
Originally Posted by RadioZero,Jul 17 2007, 03:03 PM
there is not an inexpensive aftermarket scan tool that can do everything the HDS does. i don't think the $10k snap on type stuff can do the same things as the dealers HDS.
If the TB position check and the ECU relearn procedures are really necessary when removing/re-installing the TB, and if these procedures can only be done by an HDS, then only a Honda delearship can remove/re-install the TB.
#23
If the Throttle body is replaced, you need to do the relearn. If you are removing the original, and later reinstalling you don't.
If you try and port the inlet, or modify the throttle body in any way, you'll need to do the relearn, and depending on what you do you may screw the entire thing up.
The next question is why are you removing the throttle body on a 2 year old car?
#24
As for why the TB would be removed and ported, I am sure that you know the overall goal in making power is to do so as efficiently as possible. So, if by having the TB ported I can make XX more power at the same PSI, then it will have been a worthwhile modification.
#26
Originally Posted by kenstyle,Jul 18 2007, 12:40 PM
Pardon my ignorance, but what exactly is an HDS btw?
#28
Originally Posted by RadioZero,Jul 18 2007, 01:02 PM
2QYK4U,
why are you going through the touble when you're wanting to sell your car?
Thomas Guide
12-07-2018 10:39 AM
