Has anyone here removed and installed the DBW
Is the whole part about using the HDS to do the TB position check and the ECU relearn procedure really necessary? If so, we can't simply do this type of work ourselves unless we have about $10K to spend on an HDS.
Nobody can give us more info about the HDS throttle body recalibration?
I guess we're probably the first ones out of all MY06 owners who are venturing into modifying our DBW throttle bodies.
Originally Posted by RadioZero,Jul 17 2007, 04:23 AM
the more important question: is there a way to reset the '06/'07 ECU without the HDS?
i don't think our ECU's are as easy to reset as the '05 and unders.
Hi guys along these lines I am thinking about changing my tb I have a 05 and am looking at gooing to a 70m tb, what is involved and should you armap the ecu and who cxan do the remaping? thanks the grayghost in Az
Originally Posted by RadioZero,Jul 17 2007, 12:43 PM
the scan tool has to be able to work with CAN BUS. mine does, Inova 3110. I can scan, read and erase CEL's but i cannot reset the ECU with my scan tool.
