Has anyone ever used Redline water wetter
I tried it, couldn't tell a difference. My guess is it would make a difference for pure water but, anti-freeze already has "wetters" built in.
What would you expect it to do? It's not going to make it run any cooler than the thermastat set point. The only thing you'd notice would be when the cooling system gets overworked and starts to creep, say at the track. You might see a difference then.
WaterWetter is designed to be mixed with water as a substitute for anti-freeze which is not permitted on some tracks. Although it will mix with coolant that contains anti-freeze it is not really needed and usually results in staining plastic parts, leaving a black coating on overflow reservoirs.
