Has anyone broken a comptech reinforced differential?
Old 09-10-2002, 07:04 AM
Sideways's Avatar
Default Has anyone broken a comptech reinforced differential?
I am curious as to the increased lifespan of the Comptech unit and your experiences with it. Anyone even have them? Thanks
Old 09-10-2002, 08:06 AM
Wesmaster's Avatar
I have been too afraid to really test it out. I don't plan on launching the car hard until the whole rear end is beefed up. I need about a grand or so to finish that part of the car up.
Old 09-10-2002, 11:36 AM
Jenner's Avatar
[QUOTE]Originally posted by Wesmaster
[B]I have been too afraid to really test it out.
Old 09-10-2002, 11:57 AM
Wesmaster's Avatar
Drive Shaft Shop axles. No one has done them yet. I asked them how much it would be, and they said $1,000 for a pair. They'd need to have some stock axles to look at, then they could fabricate all the parts and give the stock axles back.
Old 09-10-2002, 11:58 AM
Schatten's Avatar
1 - diff - ChrisD was going to get one a few months ago, and not sure if he went through with it. At the time, and usually, they do not have a core in house. on rare occassions they do have one, but at that time they didn't and would need to do it on an exchange basis which would take a few weeks to strengthen up.
Overall, I think the diff is an improvement but will not add security to the differntial from breakage.
2 - driveshafts - carbon fiber isn't a good solution at the moment. keep in mind, we have cv-joints NOT u-joints which can easily be fitted with a cf driveshaft or even an aluminum shaft. cf driveshafts have been used for quite a while now and you can get a custom one-off made for under $800 - but will it work correctly? most likely, but you will still have the weight of the cv-joints, and I dont know too much on the reasoning with the cv-joints as opposed to u-joints at the moment to make an educated guess at changing to u-joints and an overall lightened system.
Old 09-10-2002, 12:00 PM
Jenner's Avatar
[B]Drive Shaft Shop axles.
Old 09-10-2002, 12:12 PM
Wesmaster's Avatar
Originally posted by Jenner
Thanks for all your help Wes. How's the intercooler upgrade going?
Need cash....waiting for money...
Old 09-10-2002, 06:17 PM
HondaGuy's Avatar
What do you guys think of the Mugen LSD? This's what it said on the King M/S site:
"After two years of development, Mugen introduces their LSD for the S2000. This clutch pack 2-way LSD is much stronger than the factory LSD eliminating breakage problems so common with the S2000. 100% bolt in."
I'd like to get this, Comptech Reinforced rear end housing & the J's final gear installed all at once.
Old 09-10-2002, 07:37 PM
Wesmaster's Avatar
From what I understand 2-way is a bit much for the street.
Old 09-30-2002, 09:12 AM
Pinky's Avatar
Aren't we all!!!!!!!!
Quick Reply: Has anyone broken a comptech reinforced differential?
