Hard startup when cold *VIDEO INSIDE*
Old 10-20-2010, 12:00 AM
  #31
iDashX's Avatar
I think maybe a bad starter or teeth on flywheel?
Old 10-23-2010, 10:40 PM
  #32
SneezinCD5's Avatar
Is there a way to test it under a load? Could this be the problem as it starts normal if I turn it over by hand no more than 2 turns?
Old 10-23-2010, 11:18 PM
  #33
ahrmike's Avatar
My guess: Its a bad starter, its shorting out badly as it spins, so its killing the ignition/resetting everything. Only thing that makes sense to me, especially if its running perfectly all the other time. (not engine trouble). If its not the starter, its going to be a bad ground somewhere.
Old 10-25-2010, 06:45 PM
  #34
m5runner's Avatar
First thing I would do is check the negative cable that's connected to the chassis of the car but there are 2 things that could be the issue - alternator or starter. My bet would be the alternator. take it to autozone or one of those places and they can do a load test for little to nothing. keep us posted
Old 10-26-2010, 01:10 PM
  #35
RonnieB's Avatar
a bad starter would do this, even if it is fine at a warmer temp? why would it only act up at a cooler outside temp?
Old 10-26-2010, 02:12 PM
  #36
SneezinCD5's Avatar
Runs fine when I disconect the battery, wouldnt it turn off if it was the alt? Also what cables are you talking about that connect to the chasis?
Thanks
Old 10-26-2010, 05:24 PM
  #37
mattiouti's Avatar
check your grounds and wiring from the battery to the starter. corrosion and loose wires will ruin your day trying to diagnose this. to me this looks like a wiring issue.
Old 11-04-2010, 03:06 PM
  #38
SneezinCD5's Avatar
Looked over the grounds on the starter and the others, look good.
Old 11-04-2010, 03:37 PM
  #39
Harper Racing's Avatar
hey jason.. pick up the phone and call me... its nick...
Old 11-08-2010, 11:07 PM
  #40
Spammer
ken2012's Avatar
Remember what should be remembered, and forget what should be forgotten.Alter what is changeable, and accept what is mutable.
Quick Reply: Hard startup when cold *VIDEO INSIDE*
