Hard to get into reverse...
I need a lil help guys on diagnosing this problem:
I have 2000 and my mods are listed on my sig.
Recently i noticed that my clutch pedal became unusually light, it takes a about 1/2 of full travel to the floor for the clutch to engage. Then the last 2 days, i noticed that MY00 is really hard to get into reverse when i first start it in the morning. When i said its hard to get it in to reverse, it takes a good significant amount of arm power to get it in. Although it seems like th syncrho are not lining up. In my experience since i've been driving only manual transmission, i tend to press the clutch all the way down to the floor when i put it in reverse.
possible problem:
1. Clutch pedal has too much play.
2. Air in the hydrolic system
3. Bad pressure plate??
any suggestion or input on this problem i'm having?? Thanx!!!
possible problem:
When was the last time the system was bled? It might be worth a shot as a first step of troubleshooting to bleed the clutch. Usually a differance in feel comes from the clutch in some way. I suppose the pressure plate could be bad like you said, but does anyone really ever see a pressure plate go bad before the friction disc? I suppose if it was covered in hot spots or something but then your clutch probably wouldn't be in the best shape either.
I would bleed and adjust the clutch and see what that does and then troubleshoot from there.
I'll post the result after i get it done.
Hey same thing happened to me last week. The clutch was very soft and the engagement point was at the firewall. I bled my clutch and everything is back to normal.
Originally Posted by buggy1129,May 14 2007, 03:54 PM
Cool thanx, thats what i had it mind. I guess just wanted someone to confirm my first step.
this used to happened when i first got it,
before you start it or when your warming it up, go through the gears 1-2-3-4-5-6 then R,
keep doing that until their smooth,
btw, i think i see your car often, you stay in e.m.?
Originally Posted by SilverDC2 AP1,May 14 2007, 02:40 PM
well, im not sure if its you, but i always see a silverstone with enkei's when i pick up my friend to go to work, on central.
man can't wait to get off of work, so i take care of my S.
