hard to change gears
Old 01-07-2009, 12:19 PM
Banned
LNKs2k's Avatar
Default hard to change gears
So every since it started to get cold outside it has been really hard to change gears. Reverse is the hardest. In fact I couldn't get it in reverse until the car is warmed up.
It feels like I'm not pushing the clutch in the way but I am.
What could it be?
thanks
Old 01-07-2009, 12:38 PM
RichHawk's Avatar
Slow leak of the slave cylinder= low Clutch fluid level?
Old 01-07-2009, 12:50 PM
ahrmike's Avatar
^2nded.
Check your clutch master cylinder...its attached to the back of the clutch pedal. is it leaking?
Get the clutch fluid bled/flushed.
get clutch fluid changed.
should get much much better
Old 01-08-2009, 04:18 PM
Banned
LNKs2k's Avatar
Well tomorrow I'm going to be taking it in the shop..
Today I was almost grinding gears every time I changed gears. I started shifting with out using the clutch..
Old 01-09-2009, 10:15 AM
jyeung528's Avatar
bleed the clutch, that should fix it.
Old 01-09-2009, 01:09 PM
Banned
LNKs2k's Avatar
So a friend and I got my car high up on some blocks and we did bleed the clutch. It took a long time to pump the brake fluid through. Is that normal?
It shifts very very good in 2, 3, ,4, 5, 6 and reverse now.. However 1st gear sometimes still has a little rough time getting into gear..
Should I pump a lot more?
Over all 90% better then it was..
Thank You so Much.. All Of you
Old 01-09-2009, 01:30 PM
jyeung528's Avatar
try a rev match before you go into 1st.
jyeung528's Avatar
better yet, try a double clutch before you go into 1st.
Old 01-09-2009, 02:56 PM
Banned
LNKs2k's Avatar
i re bleed it.. It seems to work a lot better like a new clutch...
Old 01-09-2009, 03:09 PM
s2k aok's Avatar
hardtopguy.com sells the clutch master cylinder. it's not that expensive and it's an easy install.
Quick Reply: hard to change gears
