Had my Clutch master cylinder replaced recently, now clutch petal is dead again!!
Hello, hope you are all well... I recently bought a new OEM clutch master cylinder for my 04 s2000, about almost a year ago, after the clutch lost all pressure and the car was not drivable. Now the same problem has occurred but this time I don't even see a leak under the clutch pedal nothing at all. I don't know if I should buy a new clutch or what...and it is completely dead now. Please help. Thank You
check the master cylinder reservoir for fluid. if there's no fluid, you have a leak somewhere. check behind the clutch pedal to see if there's a leak. i got a reman or OE from nissin/adler that leaked (got them replaced immediately).
if there is fluid, you likely did not bleed the system enough.
Did you thoroughly bleed the clutch hydraulics?
supraken
07-24-2017 08:41 PM
