Had a loose tube -- what's this called? (Pic inside)
Originally posted by Utah S2K
Not to worry no damage!!!
The vacuum line in the picture is linked to the pulsed secondary air injection system. This system diverts air into the exhaust manifold when the car is cold. If you had tried to pass emissions when the car was cold you wouldn't have....other the that your fine. Xviper is correct in that this particlar hose would head off to the "white valve". This is a one way check valve. It is used in conjusctiuon with the air solenoid valve to assure the secondary air system is properly pressurized before the air solenoid valve opens.
Utah
Utah
Originally posted by jimbo69ny
can someone please re post this picture i think i may have a similar problem.
https://www.s2ki.com/forums/showthread.php?...threadid=105368
dn7309
08-03-2011 10:51 PM
