Guage cluster is flickering.... :(
Hey guys-
I recently had a Comptech S/C installed and this problem seems to be linked...
The guage cluster will "flicker" while at idle or very low RPM's... As soon as the RPM's go up-- The problem goes away...???
Any Ideas?
Thanks,
Matt
Any Ideas?
Thanks,
Matt
Is the car pulling power from the battery when at idle? Is the alternator only producing power when under load??
I always thought you could pull the battery out once the car was running, and it would run until you shut it off?
-Matt
-Matt
Banned
1 Post
Originally Posted by r_duff,May 12 2006, 01:58 PM
i'd replace the battery before i get to the alternator. If it doesnt fix it, then return the battery and move on to the alternator.
Originally Posted by ssmr2t,May 12 2006, 02:36 PM
i don't think that you can return battery's man
Originally Posted by darkfx,May 12 2006, 03:23 PM
I'll bet anyone a tasty lollipop its not the battery but the alternator
i have pretty new optima yellow top but my car doing same s0it man..
tell me if you fixed this problem already..
