Gruesome dropped valve photos.
Old 08-03-2013, 05:22 AM
Billman250's Avatar
Received 1,401 Likes on 839 Posts
On the dropped valve, the retainer will be floating around on top of the head under the VC.
What is the status of this one floating retainer?
Typically the keepers and the broken tip of the valve will still be in the retainer.
Old 08-03-2013, 08:38 AM
RXH
RXH's Avatar
I think the guys chucked that bit away. Couldn't find it. The car has always had a bit of tappet noise. Trouble is honda actually did the valve timings in June so I suppose if there was any damage then it would have been noticed?
Old 08-03-2013, 09:19 AM
Billman250's Avatar
Broken retainers are impossible to spot, unless you are specifically looking for them.
So you can be guaranteed if they were broken at the time of your valve adjustment, the dealer did not see it.
Do your best to recover all bits and pieces, this way you know for sure what happened.
I'm sure you don't want it to happen again...finding underlying causes is something that not many people care to do anymore. S2k engines do not just let go, there is ALWAYS a weak link somewhere. A good tech will find it, and prevent it.
Old 08-07-2013, 08:43 AM
pettyboy69's Avatar
sucks man, close to the same thing happened to me but it also shattered a rod and broke out both sides of the front of the block. I feel your pain
Old 08-08-2013, 03:59 AM
slalom44's Avatar
Did your mechanic have the opportunity to over rev thee engine after installing the clutch without your knowledge?
macr88
Drivetrain
03-28-2012 04:59 PM
06gpws2k
11-03-2007 04:36 AM
Malakas
03-19-2006 01:19 PM
StockSH
01-02-2006 07:25 AM
Quick Reply: Gruesome dropped valve photos.
