Growing oil level concerns.
Old 11-14-2015, 10:39 PM
B serious's Avatar
Received 1,418 Likes on 1,052 Posts
OP. Did you check the oil AFTER starting the car and turning it back off? On a level surface? I'd check it again now.
Unless you maybe didn't drain all your old oil out? Was the old oil fully warmed up before changing it?
Old 11-15-2015, 05:11 AM
SmokeyGatto's Avatar
pro tip, loosen the oil filter to release extra oil
Old 11-15-2015, 06:07 AM
Car Analogy's Avatar
Received 1,471 Likes on 1,086 Posts
Good tip!
Just in case anyone could ever get confused, Not with engine running!
Sent from my SM-G920P using IB AutoGroup
Old 11-15-2015, 11:16 AM
S1 S2's Avatar
Never have a problem reading Honda dip sticks.. the yellow plastic ones for mazda or VQs are way worse.
Always read the lower side.
always clean your dip stick
always start the car after the oil change and double check again.
Old 11-15-2015, 12:05 PM
Soviet's Avatar
Originally Posted by Billman250
Read both sides. The side that showed the oil level above the H after a 5 quart jug is reading high due to oil being picked up from the windage tray. The other side will read correct (basically always read the low side)
If you guys want a tip, sandblast or glass bead the end of the dipstick. Makes a dramatic difference when reading new clean oil.
This.
BigBang
12-04-2014 04:49 PM
S_KAR_G0666
09-14-2011 02:17 PM
Green Tea
08-15-2008 07:21 PM
GChambers
12-25-2002 01:39 PM
Steve2K
10-30-2002 03:32 PM
Quick Reply: Growing oil level concerns.
