Grounding points
If I recall correctly, there's one on the back of the cylinder head that attaches to the engine wiring harness.
There's a second ground that runs from the block to the subframe (intake manifold side).
and also, located next to this same ground is another ground that runs from the block to the chassis.
There could be more though, but these are the few that I've discovered while replacing the engine.
There is this PDF file of the Service Manual (2000-2003). It may help.
http://www.google.com/url?sa=t&rct=j...4IDBHCfEIImC2Q
vietdragontekx
12-23-2010 04:39 AM
