Grinding/Rattle from tranny after clutch flywheel.
How can you possibly have a broken engine mount, unless the mechanic pried the crap out off the tranny/engine to get at the upper bolts. I'll bet he put it in the same way, and bent the disc.
There are many ways to cheat when doing an s2k clutch, and they all result in problems. I'd be very suspect of the shop.
Like i said i have the today flywheel and clutch setup. Honda dealership couldnt figure it out, they thought it was throw out bearing, but car is still making the same noise... only when declerating so i dont know what else it could be....not do they
If the only buzzes loudly under decel, it's the damper springs in the clutch disc. Just like the original disc's installed in 00-01 cars and updated in 02.
The same noise is described in TSB 01-054.
And a light flywheel most often magnifies tranny whinning noise during decel in gear. Not just the S. Happened to my miata as well.
To the original poster, does the noise go away while driving when you depress the clutch but stay in gear?
I have had friend with Aluminum flywheels on other cars / trucks / mustangs....
Yes they do make noise.... chatter.... throwout bearing....
like a marble loose in trans
maybe the S2000 is different.... I have never asked to hear a Alum. S2k flywheel
Originally Posted by HvRRZ,Jan 15 2006, 10:40 PM
wow this is an old thread, but yes the noise does go away when I stay in gear but get on the clutch.
I guess you should've found out the answer by now.
Originally Posted by Race Miata,Jan 16 2006, 01:40 AM
Oh, haha! I just noticed Jan on the date. Didn't realize it was Jan 2005!
Yeah, I had an aluminum flywheel and got rid of it. The rattling did get pretty bad.
Tim
Tim
