Grinding noise on startup even after replacing starter...
Old 06-18-2016, 07:36 PM
maaaaackle's Avatar
Default Grinding noise on startup even after replacing starter...
Hey guys, i recently replaced my starter that had an unknown number of miles on it because it was making an awful grinding noise when I would start the car.
When I put the new starter in, i put a little grease on the little starter gear that engages the flywheel as a preventive measure against that grinding noise.
Well, lo and behold, the grinding noise is still there. Its not as terrible as it was with the older starter, but its definitely annoying. Is this something that is just inherent with S2000 starters? Or did i do something wrong? All the connectirs going to the starter are connected as securely as humanly possible so I dont think its that. I also got a new battery to no avail.
Any insight?
By the way, the starter that went into the car was pulled from an s2000 with 33,000 miles.
Old 06-18-2016, 07:39 PM
AlexSobe614's Avatar
Have you checked the flywheel? Maybe some teeth are gone or something that could cause that bad noise. My car doesn't have that problem though and I don't think it's a common issue
Old 06-18-2016, 07:47 PM
maaaaackle's Avatar
I have not checked the flywheel. I suppose that would be the next best thing to condemn...
Old 06-19-2016, 03:43 AM
freq's Avatar
Starter motor over-run is pretty common on the S2000. Mine has done it forever.
Old 06-19-2016, 04:14 AM
Billman250's Avatar
Received 1,403 Likes on 840 Posts
Mine too. Flywheel is very likely fine.
Old 06-19-2016, 04:21 AM
Car Analogy's Avatar
Received 1,470 Likes on 1,086 Posts
...and its more common the colder it is outside. In the colder months mine sounds aweful. Come warmer temps, it works perfect. Yet occasionally on a cool morning, if it was left outside overnight, it will still do it.
Sent from my SM-G920P using IB AutoGroup
Old 06-19-2016, 06:37 PM
Forziii's Avatar
This noise used to annoy me SO bad.
It still does, but not nearly as much.
Louder exhaust helps to hide it especially on cold startups lol.
Old 06-19-2016, 11:08 PM
maaaaackle's Avatar
thanks for the input guys. I was sure that it was just a thing that plagued s2000s.
but damn is it annoying...
Old 06-20-2016, 08:06 AM
How cold is it there where you are now?
Old 06-20-2016, 09:54 AM
maaaaackle's Avatar
Not cold in the slightest. Im in socal. As of right now its 108* and the low tonight will be maybe...78.
Quick Reply: Grinding noise on startup even after replacing starter...
