grinding noise in starter?
#21
Mine has started to do it more and more. I'm also worried about something stripping out, but it only does it when cold. Very annoying and taking the starter out would be a major pain in the ass, as the intake manifold has to come off.
#26
as said above it is the gear on the starter sticking. i found that if i let go of the starter button just before the car is actually started, it doesn't grind.
#27
yep, starter. replace it or rebuild if you can.
https://www.s2ki.com/forums/index.ph...f=133&t=356924
#28
Originally Posted by 04S2kSS,Jan 8 2011, 05:32 PM
Its the gear on the starter it isnt retracting back fast enough therefore its sounds like an overcrank.... Its your starter. i replaced my battery not to long ago and it doesnt do it as often
I suffer from the same issue, it's just where it gets stuck for a bit, rpms raise and then it slides loose... think grease may work on it, just got to be careful how much you put on? Don't think with flywheel etc spinning that the grease could land anywhere near the friction surface of the plate?
It all depends on the problem, is it because there is extra friction so the gear teeth stay together longer? Or is it the way it retracts back in to the starter motor that's causing the issue? Also I got a new battery about February and during operation pumps 14.9V and it can still make the noise on startup... (so may not remedy all probs)
