Grinding
My '00 has never ground any gears except when I was not paying attention or when it was VERY hot and I had been beating on it to get the tranny even hotter. I will grind second maybe a couple times a year. I have not considered it a problem.
My 01 did grind 2nd.I rebuilt it and it fixed the problem for several thousand miles.Problem later returned and i replaced the box with an my 05 unit.This box is much better in my opinion,but you have to still pay attention when shifting rapidly at high rpms.Once in a great while i might catch a slight grind when i'm not paying attention.Still its not even close as bad as my original 01 box.
3354.06
dealer price would be 4472.07, assuming they don't mark up more than honda's list (some do).
http://www.hondaautomotiveparts.com/auto/j...NSMISSION++ASSY.
Mine grinds second...my clutch disk buzzes too. Even with these it's not much of an issue to me. I actually don't mind it because I'm less prone to beat on the car knowing that if I shift too quickly it will grind. I take good care of her as a result
I'm thinking about doing the clutch soon, probably sometime this spring. Because my car is out of warranty I don't think I'll ever replace the synchros, I've seen 04+ Trannies go for as little as $1500 used, I plan on purchasing one when mine gets out of hand.
![smile.gif](https://www.s2ki.com/forums/images/smilies/smile.gif)
