Grind from 1st to 2nd shift FIXED
Hey guys,
I know a lot of people have this problem so I figured I would let you know what I did. Unfortunately it is nothing new and probably something that you already tried but hey...
I got the car last summer with 46K Km on it. The 1st to 2nd gear shift was grinding a bit, nothing crazy but enough to be enoying so last weekend I changed the tranny oil with OEM honda and damn! So much smoother, no grind at all!
I don't know how long this is going to last but if you have the grind issue and have not changed your oil, DO IT!
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-5yr.png)
Should always switch out fluids when you first get the car (unless the records you get show it's been done recently). The shifting should stay smooth for a while. Glad you got it fixed!
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
Good work on the fluid change, glad it worked for you.
![thumbsup.gif](https://www.s2ki.com/forums/images/smilies/thumbsup.gif)
Little update on this.
The first to second gear grind is definitely gone but a week after I changed the oil, the first gear started to pop out when the car was cold. It only happened twice but it scared the shit out of me big time! I read a lot of threads about this, but they suggested all sort of reasons. So I just went with my guts feeling and past experience and added more oil in the trany. Originaly I followed OEM specs but now I added maybe 350ml. I basically could not fit anymore as it was driping... The gear never poped after and the trany is SO smooth!!!
So if you have odd trany issues, play with your oil lol!
lunardeathgod
06-19-2012 03:47 AM
