Greddy Oil Cooler Kit for S2K? Anyone have one on their cars?
I've got the larger version installed, it mounts vertical not horizontal like the picture. Location is in front of the radiator on the left-middle side next to the silver aircon valve in the middle. You can choose to run the cooler kit with or without the OEM oil cooler block. I chose not to use it because it doesn't make a difference from my oil temperature reading. Normal street driving reduces oil temperature significantly (65~75DC) while under high load, oil temperature constantly remains under boiling point (90~95DC). Should oil temperature pass boiling point (100DC), it's a clear indication to change the oil. Motul 5V30W racing oil used.
Trust site shows 2 versions. The smaller version has less coils (10), if I can remember and (14) for the other. Kit comes with everything you need. Oil draining is required with an additional 1 litre of oil to be added due to cooler increasing oil capacity circulation.
I remember seeing pics of the spoon race car (N1 spec) and it was running an oil cooler. Whenever I get my oil pan finished (w/ baffles) I'll be able to find out what kind of oil temps I'm running at the track.
-ardy
-ardy
Originally posted by SSS 01
... Should oil temperature pass boiling point (100DC), it's a clear indication to change the oil. ...
I have seen consistent 120C+ at the track, and I think I could do with some additional oil cooling.
However 65-75C seems awfully low for the street and somewhere north of rated operating temperatures. Isn't there a solution that incorporates a thermostat into the system? That would be ideal...
