greddy emanage fuel trim question
I know with the apexi vafc the computer will retrim the fuel curve to what the computer sees as optimal. Will the greddy system also have the same remapping problems? And Yes like always, I did a search and did not find this info. Thanks again.
Not sure if I understand your question. The VAFC does not retrim the fuel curve to an optimal setting on its own. You have to tune it yourself to what you feel is an optimal setting. If you are asking if the greddy emanage has fuel tuning capabilities, then yes it does.
You can get a description of it from Greddy's website
http://greddy.com/products/electronics_frame.htm
Greddy's basemap starts at zero, this means stock fuel at the factory ecu. Any numerical number above that is an increase of percentage of fuel over stock. If you put bigger injectors you just tell the emange and it autocorrects or trims it to the stock levels. Forexample if you put 550cc's in they will act like stock until you modify the fuel curve by adding or taking out fuel
seoul2k
03-15-2011 06:22 AM
