Greddy E-Manage
#31
My observations and results so far are
1. VAFC is only good with the NA and Vortech setup. I was able to control AF ratio nicely in both applications.
2. Emanage may struggle with injectors larger than 600cc. As I recall, Jenner had a fair amount of problem controlling his 700+cc injectors and ended up replacing the emanage with the AEM.
3. AEM is excellent but still not 100% yet. There are still a few bugs. I am still waiting anxiously for mine as horsepowerfreak.com is still waiting for the AEM wideband display thingy , so I can't say more than this.
Just my 2cents contribution today
#32
Yes the Greddy emanage can control more than 600cc.
Here's proof. I talk to this guy quite a bit and he has a supra with 850 cc injectors and runs the greddy emanage. In fact he sells the greddy emanage on his site.
http://www.mohdparts.com/supra/index.html
www.mohdparts.com
-Trung
www.mohdparts.com
-Trung
#35
Yes, but thats related to the ratio of the old/new injectors. It gets to the point that the map feed into the stock ecu gets so low that strange things start happening. For instance, it becomes impossible to maintain a steady state driving speed because the slightest release of the throttle causes the ecu to totally cut off the injectors.
#36
Right, but different OEM ECU's may behave better or worse than others when using large injectors with the eManage. For example, you may be able to go 2X on a Supra, and only 1.6X on an S2000.
#38
with my setting: (Comptech Sc and A/C, stock boost)
plus 550 cc and bigger fuel pump than the Comptech provided and removed the Comptech FRP.
Can I take a new blank emanage and just input the injector conversion ration and clap the map sensor to 2.9 V and run the car normally until I go to the dyno to tune it??
Juan
Juan
