Grease question
Grease question
I'm almost out of Redline CV2 and am in the process of rebuilding a prop shaft for someone, my question is can I use my Mobil 1 synthetic grease? CV2 is a NLGI 2 grease with service rating GC LB, the tub on my Mobil 1 grease says it exceeds GC LB service rating but does not say specifically if it is a NLGI 2 grease.
My question is would it be ok to use the Mobil 1 grease or just wait for delivery of the Redline grease I ordered?
At the mobil Homepage the Mobil 1 grease is also rated as NLGI 2:
https://www.mobil.com/en/lubricants/...thetic-grease/
Slowcrash_101 (11-07-2020)
Received 1,377 Likes
Greases are not always compatible with each other.
Redline says its compatible with *most*.
Not sure what M1 says.
Not sure what both contain.
I would just order more redline on Amazon and have 1 or 2 day delivery.
Or use all M1 if you haven't started yet.
The proper grease for a tripod 'cv' joint is nlgi#1. When people use cv-2, they are technically using the wrong grease. It seems to work though.
I washed the bearings on the prop shaft in mineral spirits then packed them with Redline I had just enough to do both CVs.
Be careful with the snap rings, they're easy to permanently distort.
Speak for yourself. I recently performed this operation. Made careful consideration before choosing my lubrication, and I have to say I'm confident in my penetration...
