Greaaat. Start noise?
Old 01-09-2012, 06:56 PM
Kirpich's Avatar
OP, I don't know if using oil is a good idea, it will help for a bit, but then the dust from the clutch will stick to it creating a weird goo.
Maybe cleaning, and then some graphite? Just stabbing at theories here.
Originally Posted by S2_4SHOOR
Mine does this too. In fact mine's worse. Sometime mine don't even crank. Battery is new. Starter is next thing I would aim for.
Don't mean to jack the topic, but 'bad' starter engagement, i.e. no crank, or poor crank speed, could be because of a bad engine-to-frame ground connection. I think there's one right by the starter, it's a thick multi-strand wire, from engine to frame. There may be another one on the passenger side, I don't remember. If they're loose, you'll have trouble starting.
Old 01-10-2012, 10:24 AM
SgtB's Avatar
You want grease. Everything in the clutch system uses grease with no ill effects.
Old 04-13-2012, 08:29 PM
AZ-S2000's Avatar
Well, Im getting the OEM clutch installed soooo I can go ahead and do all this
Chugs
04-03-2015 02:53 AM
lovegroova
08-06-2012 08:28 AM
p0staboy
05-14-2012 06:18 PM
killereclipse
01-25-2008 03:21 PM
Feezy
12-01-2004 05:31 AM
Quick Reply: Greaaat. Start noise?
