Greaaat. Start noise?
Old 01-08-2012, 11:19 PM
AZ-S2000's Avatar
Default Greaaat. Start noise?
Replaced the clutch with new clutch kit, throw out bearing, and greased what I needed to grease. This was about 3-weeks ago, since then no issues what so ever. Now, take a listen. Disappointing to say, since I wasn't expecting any issue from this. All was torqued down. Anyhow if this requires me to remove the transmission I wouldn't mind toooo much since I want to get rid of the Stage-4 I put in. What do you guys think? And no I'm not holding the starter button for too long if anyone was wondering that.
http://www.youtube.com/watch?v=zjHyz...ature=youtu.be
Seems like this is not rare, found another video of the same noise
http://www.youtube.com/watch?v=_nSoTfw3rrk
Old 01-09-2012, 05:45 AM
Reckon's Avatar
Not sure what that could be...
Old 01-09-2012, 05:48 AM
Importedpower's Avatar
starter not pulling back fast enough, mine used to do it pretty often... dont take my advice for the bible or anything but check your mounts... i replaced all of my motor/trans/diff mounts and it stopped doing that. My passenger side motor mount was completely destroyed, but you couldnt tell until you jacked up the car, put it on stands, then jacked the motor up a bit, it was torn almost completely off.
Old 01-09-2012, 05:55 AM
Billman250's Avatar
Received 1,395 Likes on 836 Posts
Sticking starter, guaranteed.
Motor mounts are not related.
It could get worse or better when you changed the flywheel, if you did.
The problem is the starter, mine does it too.
Old 01-09-2012, 05:59 AM
Not to stir up anything but if a motor is rocking a little hard when trying to start up it could contribute to the starter moving around a bit and getting hung up?
its all connected together...
couldnt hurt to check the mounts, might find he needs to replace them, worst case they are in good shape and its not the problem
Old 01-09-2012, 01:07 PM
AZ-S2000's Avatar
Motor mounts replaced already. I was thinking to grease/lube starter up?
Old 01-09-2012, 03:58 PM
SgtB's Avatar
The teeth on the starter where worn to match the old flywheel. There are probably small lips and gouges on the stater gear that don't quite match causing a lag in retraction and a grind.
You can file any small rough spots off the gear and grease to action. I would use a higher grit sand paper to polish any filing you did as well,
Old 01-09-2012, 06:20 PM
AZ-S2000's Avatar
Funny how sooo many of us have these issues and no word from Honda oh well. I'll get on this soon
Old 01-09-2012, 06:32 PM
SgtB's Avatar
Them's the breaks. Honda will never do anything about it. I chalk mine up to an aftermarket FW and 145k.
Old 01-09-2012, 06:40 PM
S2_4SHOOR's Avatar
Mine does this too. In fact mine's worse. Sometime mine don't even crank. Battery is new. Starter is next thing I would aim for.
Quick Reply: Greaaat. Start noise?
