got a vibration...left rear...slow speeds.
#21
Originally Posted by efthimios,Jun 27 2006, 05:06 PM
X I thought that the ap2's do not need the spacer? this is not factual, just off of what I have read (I just learned )
#22
Originally Posted by xviper,Jun 27 2006, 07:01 PM
Some cars that don't have spacers have been known to go happily down the road without any issue while others may not be so lucky. Why the difference?
#23
Originally Posted by efthimios,Jun 27 2006, 08:07 PM
chance? my 02 was dropped 1.5" for 3yrs & 70k mi and never an issue with that...another semi local w/ an 02 and less miles & dropped ended up with that issue....luck maybe.
#25
Originally Posted by xviper,Jun 28 2006, 03:25 AM
It could also have something to do with what kind of wear pattern the CVs had before the drop.
I have a vibration from left side rear during acceleration (specialy when accelerating in right corners) and at engine braking at 120 km/h
I can
#26
Originally Posted by Skogshuggarn,Jul 5 2006, 04:40 PM
ok, sorry but my english is quite bad, so could someone post some pics of the diffrent parts you are talking about?
Outer CV joint:
You can't check these unless you take the boot off and take the joint apart.
The spacer gets sandwiched between the rear diff output shafts (2) and the 1/2 shafts (2).
Look at this website to see the spacers and where they go.
http://www.aj-racing.com/catalog/product.p...&cat=114&page=1
Here's a commercial picture of the 1/2 shafts. The CVs are inside the rubber boots:
http://www.aj-racing.com/catalog/product.p...&cat=114&page=2
#27
Originally Posted by blacky,Jun 27 2006, 11:58 AM
sorry PLYRS 3, but im having the same problems too. need advice as well. this vibration happened when i lowered my car. i asked around and alot of ppl are clueless to this situation. mine vibrates during acceleration around 50-70... but once the gas is not pressed, they go away...i took it to get it balanced and also got an alignment but its still there. lugs nuts are tightly screwed on, so thats not it...i put on my stock rims but it still vibrates. any help would be great guys.
I cannot enjoy my damn car.
#28
Originally Posted by xviper,Jul 6 2006, 12:24 AM
Inner CV joint (inside the rubber boot):
Outer CV joint:
Outer CV joint:
Or do I have to buy new driveshafts or drive shaft spacers?
#29
Remove the shafts and swap the drive buckets (you can't swap complete shafts as they are different lengths). It's a surefire fix, it's easy, and you don't need any new parts. The buckets will now be operating in reverse, on a new drive surface. You likely have pits on the inside of the buckets.
This is VERY common, and I've fixed plenty of them with the bucket swap.
#30
