Going to replace tranny/diff fluid this weekend..
Is this the LE1605 that I need for the differential? And I'm guessing i'll need just slightly more than 1 bottle to fill it up? I used Amsoil the last time.
ALso, what do you guys use for the tranny? I used the Friction Modified Synchromesh from GM last time. ANy better fluids out there for the tranny?
Thanks!
Thanks!
I've never personally used LE before so I can't comment there but if it's GL5 for hypoid gears and 75W-90/110/140 then its fine for your diff. GL4 for the tranny. You could also consider Honda MTFIII from the dealer for your tranny.
![](https://www.s2ki.com/forums/images/s2ki/ranks/com_organizer.png)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
Yes, another fluid thread.
![thumbsup.gif](https://www.s2ki.com/forums/images/smilies/thumbsup.gif)
![](https://www.s2ki.com/forums/images/s2ki/ranks/member.png)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-5yr.png)
Been sleeping the past couple weeks and couldn't drop by here? ![smile.gif](https://www.s2ki.com/forums/images/smilies/smile.gif)
LE-1605 is NOT a GL-5 lubricant. Not anymore. Old formulation was GL-5 but it's not the same. Changed this year I think.
Anyway there's an extensive, fairly contentious, argumentative thread running with all the information I won't repeat since we don't need 3 or 4 threads on LE-1605.
Grab a coffee or beer and start reading. Bottom line remains the same. LE-1605 is not a GL-5 lubricant.
-- Chuck
-- Chuck
Honda came out with MTF3?
-- Chuck
-- Chuck
