Is this going to be an issue?
So I just installed a password JDM front strut bar on my S2000. Yes...I know this bar does little to nothing for performance, BUT I picked it up used (for an absolute steal) off of a local S2000 owner. I was reading online and read somewhere this bar was supposed to come with a cruise control bracket, but I did not get one. And I have contacted PWJDM to try and buy one, but have not heard back from them. I ran the cruise control line underneath the bar. It is barely touching, but it is touching. It does not look like the line is kinked in any way, but I just wanted to verify this is not going to a problem. Or that this will not damage the cruise control in the long run. I first tried to run the line through the holes in the bar, but it looked like it was creating more pressure that way, and I didn't like the idea of running it through the bar. The cruise control works fine while driving, and the throttle is working normally too. Anyways...pictures to follow. Let me know what you guys think!
Thanks
Thanks
It won't affect anything, to reduce a wear spot on the cable you can put a small piece of rubber hose around the cable in the contact spot. Did you try running it above the bar ?
MisterMonkey26
06-18-2009 05:06 AM
