Going to install 4.57.... Any advice ?
#21
Originally posted by RT
..... multiple stacked spacers made of correct material is far better than single spacer made from wrong material (make sure quicky machine shop job is not too "quicky")
If i have to have a machine shop make a spacer for me i'll bring the OEM one i already have in the diff. to make sure they use the same material.
Thanks
#22
The shim is hardended steel. Don't bother going to a machine shop unless they can do heat treating. The shim is ultra precise. Use the thin shim, and stack a hardened shim on top of it. You would need to measure the stack height with a micrometer to obtain the right size.
#23
I went to a machine shop with the final combo of the thin shims supplied by RICK'S and i asked the guy to made a shim to match the total thickness of these and this with a hard material.
When i finaly assembled the ring and pinion with the new shim, i have checked the gear patern and it was perfect. I have set the backlash to .006 and i was ready to close the back cover and put the diff. back to his place.
#24
I was told backlash should be .008
That is what mine were installed to
Also, would have suggested having them cryo-treated before install but . . . . not necessary, just nice to have
Good luck and let us know how much harmonic noise you get OK??
#26
http://forums.s2ki.com/forums/showthread.p...threadid=205311
#27
Like swtazn97 said ( and it make semse ! ) if you set the backlach at .006 it is possible that after the break-in procedure it will expand to .008 and since he don't have the whinning sound i tought it would be a good idea to try it.
But : I have a whinning, and this, from 40 mph ( very faint noise ) to 80 mph ( with the top up it could be very annoying for some people ) and then, at 85 it completely dissapear
I have this whinning only when cruising not when decelerating.
But this noise doesn't bother me since i know it's not a matter of a ( bad installation ) but a matter of ( gears made to be strong instead of being made to be quiet !
And it is so much more fun to drive the car now !
#28
#29
[QUOTE]Originally posted by Squeezer
the shim kit is $132.51 http://www.hondaautomotiveparts.com/auto/j...AR+DIFFERENTIAL see #11 [/QUOTE
But it's in U.S. dollars !!! In Canadian it makes 350 with the exchange, the taxes and the duty !!
And it would be useless because the shim i have asked a machine shop to make is thinner than the thiner one in the Honda kit.
But thanks for the info !
