Going Crazy over Misfire o_O
Old 01-27-2015, 06:05 PM
Slowcrash_101's Avatar
I have removed the header to do my clutch...
Old 01-27-2015, 06:39 PM
Utah S2K's Avatar
The information on this thread is related to Nelson and his specific issue. Thread "hijacks" are frowned upon here as they lead to confusion and misinformation. If your specific car has an issue then start a thread. I would be more then happy, as would others, to offer advice. So the question is does Nelson have an aftermarket header not did Slowcrash do a clutch job. Don't mean to be an ass but having been here 14 years I get tired of this nonsense. Start your own thread!
Utah
Old 01-28-2015, 10:08 PM
Nelsons2k0's Avatar
Guys! It went away after I seafoamed the Pistons! No more misfire thank you all!!
Old 01-29-2015, 04:27 AM
chubbys2k's Avatar
So im guessing lots of carbon build up?
Old 01-29-2015, 05:33 AM
Billman250's Avatar
Received 1,403 Likes on 840 Posts
I urge everyone to NOT use seafoam as a cure for a misfire. The OP got very lucky.
Leakdown would have been my course of action.
Old 01-29-2015, 06:32 AM
MR.T's Avatar
Originally Posted by Billman250
I urge everyone to NOT use seafoam as a cure for a misfire. The OP got very lucky. Leakdown would have been my course of action.
What's your reason billman? I've always wondered about an induction cleaning through an intake vac port. I've also wandered why such a thing doesn't hydrolock motors. Is it because the seafoam, unlike water, can actually compress, or just simply combust??
I've been doing a once a year treatment on my rover and never had an issue. I never put it in my tank or crank though.
I'm scared to try on the S.
Old 01-29-2015, 08:27 AM
Banned
wadzii's Avatar
Mr.T that stuff can hydrolock a motor.. saw it happen several times when I worked at the dodge dealer. the cleaner would puddle in a corner of the intake manifold, then when you hit the gas it would suck all the cleaner into one cylinder and lock it up.
There is usually not enough of the cleaner released into the engine to cause a hydrolock. If the chamber is 50cc and you only put 3cc in, it wont hydrolock.
Old 01-29-2015, 08:45 AM
Billman250's Avatar
There has never been a single car in history that I needed seafoam to repair, nor will there ever be.
Old 01-29-2015, 08:53 AM
Well I hope I don't get accused of thread hijacking again, but I too fixed my misfire. I checked my exhaust manifold and lo and behold two of the bolts were not as tight as they should be. Problem solved, thanks FWIW.
Old 01-29-2015, 09:01 AM
odb812's Avatar
The problem with seafoam is the way it is used: putting it through some system on a running motor to break up carbon. When the carbon is broken up, the particles are still very hard and have no where to go but right through the combustion chamber and out the exhaust. I have no proof that it damages anything, but I don't want to be the one to find out.
Quick Reply: Going Crazy over Misfire o_O
