Going all redline fluids
I'm going all redline fluids, just for the hek of it.
Did it get these numbers right?
10w30 synthetic oil
6 quarts
8.99 a quart
53.96
MTL trans fluid
2 quarts
8.99 each
17.98
75w90 diff fluid. Is this what I need? What's lightweight shockproof gear oil?
2 quarts
8.99 each
17.98
Total Cost: 89.92 before tax
Thanks for the help
10w30 synthetic oil
6 quarts
8.99 a quart
53.96
MTL trans fluid
2 quarts
8.99 each
17.98
2 quarts
8.99 each
17.98
Thanks for the help
10w30 synthetic oil
6 quarts
8.99 a quart
53.96
MTL trans fluid
2 quarts
8.99 each
17.98
2 quarts
8.99 each
17.98
Thanks for the help
10w30 synthetic oil
6 quarts
8.99 a quart
53.96
MTL trans fluid
2 quarts
8.99 each
17.98
2 quarts
8.99 each
17.98
Thanks for the help
Originally Posted by tcjensen,Dec 9 2006, 11:57 PM
so 75w90 is the right stuff for the diff?
would you recommend mt90 instead of mtl for the trans?
Ok. I did some searching.
Definitely not using the shockproof stuff.
Sticking with the MTL through these colder months, then will switch to MT90 in the spring.
Going with
10w30 synth oil-7 qts
MTL trans fluid-2 qts
75w90 gear oil-2 qts
Thx for the input! Bout 100.00
Going with
MTL is the correct fluid to use in the transmission, it matches Honda MTF viscosity perfectly. I'm using it and love it. If you for some reason truely feel that the MTL is too thin then try a blend of MTL/MT-90 before switching to straight MT-90.
The rear diff only takes ~.8/quart so you don't need to buy two bottles. LE-607 is the best choice for your rear diff unless you drive the car in temps that dip below the 30's. If you drive your car in all seasons (and have cold winters, which I bet TX doesn't), then Mobil 1 75W-90 or Redline 75W-90 will do the trick.
The reduced life can be caused by the interaction of the different detergent packages in the oils. Most oils aren't meant to be mixed.
Originally Posted by slipstream444,Dec 14 2006, 12:14 AM
Mixing oils - while not necessarily a "bad" thing - is not a good idea either. According to some of the info I've read in the Oil Journals, and from talking with Amsoil tech service in the past, there's a possibility you'll actually reduce the life of the fluid by mixing it...
To the OP, from a big fan of Red Line:
1. Good job not falling for the "I use Mobil 1, and I've never had a problem" line -- Red Line's just better oil.
2. 10-30 is your best choice in TX, but Northerners will need 5-30 in winter.
3. I have Red Line in my diff right now, but after doing a lot of research I've concluded that LE-607 really is better.
4. Try the MTL in the transmission, but understand that transmissions seem to vary in their preferences for some bizarre, inexplicable reason. If your shifting is notchy, try something else, either the new Honda fluid or the GM Synchromesh FM. Or Amsoil, I suppose. Don't be such a purist that you stick yourself with what could be, for you, an inferior product.
