GM Synchromesh: If it isn't broken, fix it?
I'm fascinated by the universal praise of GM Synchromesh fluid. My problem is that my transmission shifts perfectly just as it came from the dealership. I've only owned manual transmissions, so I'm not a shifting newbie. I cannot imagine a better shifting transmission than what I've got now.
I've got about 4,000 miles on my car. Is there any reason why I shouldn't just change to GM Synchromesh anyway?
If I do, I'll probably have the dealer change the transmission fluid.
If your car is over a year old, you should probably consider changing your tranny fluid with Honda MTF, since it seems to work well for you. You should change your differential fluid too. I haven't heard from anyone who wasn't completely disgusted by the color and smell of their old diff fluid.
[QUOTE]Originally posted by gernby
[B]If your car is over a year old, you should probably consider changing your tranny fluid with Honda MTF, since it seems to work well for you.
Originally posted by JohnnyG
3 - Shifts into 6th correctly without having to hold the shift knob differently (wasn't expecting this)
