Getting ignition replaced to fix key sensor
When I take the key out after turning off the car, it keeps beeping if the door is open and I can't lock the car until I put the key back in the ignition and take it out again so the beeping stops. The dealer already tried adjusting/lubing it twice and now wants to replace the ignition! I've read of other people having this problem... What did you have to do to fix it?
This is covered under warranty BTW.
I have the same exact problem with my '06. Ever since it had 1k miles on it, I have about 6k now.
It was ok at first, but it is starting to get agravating, so I will probably have it checked out.
