Gear grind while clutch is depressed
So a couple months back I was starting off from a complete stop and went smoothly through first.
I went into second gear and added throttle but the engine just revved like it was in neutral.
I depressed the clutch pedal and moved the gear lever down about an inch more and at that moment there was very noticeable gear grinding.
The car has been driving fine since then until today when I accidentally did the same thing in third.
It can best be described as going into the right gear gate but not far enough in to be fully engaged. Also keep in mind the clutch pedal is fully depressed/no throttle is being applied when the grinding occurs.
What can I make of this scenario? Should I be double clutching before moving the gear shift into place after the "mis-shift" ?
the search came up with grinding issues that seemed to be clutch involved/applicable to AP1 only.
Thanks in advance
Thanks in advance
I have the same issue except in first and second gear. Like sometime when I put the lever in first, it like it sitting in neutral instead. When I give it gas and it rev up and notice that it rev much quicker with out moving, then clutch in and force it into first gear, grind. I have about 38k miles on my clutch
Originally Posted by ikeyballz,Sep 14 2009, 02:47 AM
That grinding is normal - you werent in gear, you tried to force it in while the car was still moving/engine wasnt matched, synchros couldnt catch up fast enough so grind.
