Gauge Lights Flicker Upon Warmup
Old 01-28-2014, 04:00 PM
beyondredline9k's Avatar
Default Gauge Lights Flicker Upon Warmup
Hello,
I have been having this issue now for the past couple weeks and can't figure it out. It seems when I turn my car on in the morning, the gauges lights (Battery, Brake, EPS and SRS) randomly flicker. I checked the battery terminals and they are snug. The car starts right up without any problems and drives fine once the lights stop their flickering. I've attached a video and hope an electrical guru can guide me in the right direction.
http://www.youtube.com/watch?v=-Vlxh...ature=youtu.be
Old 01-28-2014, 04:25 PM
Billman250's Avatar
Received 1,401 Likes on 839 Posts
Almost seems like a bad ignition switch.
Jiggle the key... See if you can get the dash lights to respond.
Old 01-28-2014, 04:34 PM
Thanks for the quick response... I will give it a shot in the morning.
Old 01-28-2014, 04:41 PM
DrakeValle's Avatar
This can also be related to the alternator sometimes.
Had a similar issue with my 2001 Tiburon.
Old 01-29-2014, 10:32 AM
I tried wiggling the key when it was occurring but the issue continued.
Is there a simple way to check the alternator to see if this is the issue? I've owned this car since 2004 and never had a issue like this...
Old 01-30-2014, 03:36 AM
Billman250's Avatar
A glitchy alternator (meaning the rectifier in the alternator) will cause the dash to flicker, but will not cause your warning lights to go on and off.
Any major work done to the car? engine job? Alarm?
Old 01-30-2014, 03:39 AM
Billman250's Avatar
Looking at your vid again, its hard to say.
Write down each light that is coming on and post it. They obviously have something in common.
Old 03-07-2014, 11:30 PM
PaGEmaZt3r's Avatar
Originally Posted by Billman250
Looking at your vid again, its hard to say. Write down each light that is coming on and post it. They obviously have something in common.
I'm having a low idle problem after engine overhaul. I've noticed my dash lights flicker just enough for me to barely see it. Could my alternator be the cause of my idle issue?
Old 03-08-2014, 04:49 AM
The lights are: battery, brake, EPS, and SRS. The power steering kick out when the lights are on. Sometimes instead of flickering they stay on for 5-10 seconds and then go away. It happens only when the engine is cold.
The other day I left my running lights on while I was at work. This drained the battery down pretty low where it struggled to start. Once it finally started, it had no symptoms what so ever. I'm starting to think it has to be the alternator. Are there any test I can do before ripping it out and wasting time if it isn't the alternator?
Thanks for the responses.
Old 03-10-2014, 01:58 PM
Bump
billiardboy904
08-03-2018 08:38 AM
dak24
03-12-2015 06:44 PM
dak24
08-13-2013 06:24 PM
DCIdevil
06-06-2009 07:40 AM
bronzed
09-20-2004 08:58 PM
Quick Reply: Gauge Lights Flicker Upon Warmup
