Gates Serpentine Belt
kjonesy203 (05-17-2020)
Should you replace the oem belt on a car that has very low mileage and no apparent issues with the belt? Just on age?
I would but having once been marooned in Death Valley in my younger years with a ten year old belt on a 1970 Buick GS made me overly cautious. Since then I have changed many belts, surely many more than necessary. My thought is that the belts degrade over time. Your mileage will probably vary!
kjonesy203 (05-24-2020)
If the Gates number for non AC CR is K060450 then the Gates catalog is in error.
Gates lists the non AC CR belt to be K060448. You can also take advantage of their RPM series for the Non AC CR.
K060448RPM.
K060448RPM.
Rubber degrades with time, just like tires regardless of the miles on them. Changeling perishable parts is preventive maintenance which beats a breakdown every day. The serpentine belt is kinda important. Water pump, and alternator for starters -- as if more is needed. The pulleys and idlers are known areas of bearing failure. Check them while you're in there.
Gates is a decent brand. So is the Honda OEM part. Why skimp?
-- Chuck.
-- Chuck.
