Gasoline Gauge
Have you had this car from new? Do you have or know if the car has had a supercharger or turbo at one time? I'm thinking it might have the high output fuel pump put in and we all know that the fuel filter on these things causes the fuel level float to not move through its full travel. If this is the case, you'll need to pull the fuel pump out and twist the fuel filter slightly out of the way.
If you think you have the original fuel pump and the gauge has alwasy done this, then go to the dealer and get it fixed.
