Gas leak
Old 08-23-2016, 05:19 PM
s2kbtos's Avatar
Default Gas leak
There is a lot of gas coming out of the top part of the injectors. Theyre all leaking bad. Do i need to buy a new rail?
Old 08-23-2016, 06:06 PM
s2kbtos's Avatar
I may try to replace the rubber gaskets on the injectors. Where can i buy those rubber gaskets?
Old 08-23-2016, 11:21 PM
Soviet's Avatar
You shouldn't need to replace the fuel rail. You should be able to just replace the o-rings that sit around the top of the injector.
I believe the part # is 91303-PK2-005
I bought some at the dealer and I would recommend doing the same unless you know what you are doing. The o-ring has to be resistant to fuel obviously.
Old 08-25-2016, 03:23 PM
jyeung528's Avatar
what causes these o-rings to leak? is it an inspection/maintenance item or should they be able to last forever?
Old 08-25-2016, 03:30 PM
Soviet's Avatar
Any rubber o-ring/gasket will flatten and fail to seal over time. I've also damaged them when removing/installing the fuel rail onto the injectors.
Old 08-25-2016, 05:44 PM
afzan's Avatar
get new o-ring's from the dealer, be careful when reinstalling the injectors - it's easy to tear them
Old 08-29-2016, 09:12 PM
jyeung528's Avatar
so since all fuel injector o-rings will fail over time, shouldn't inspecting the fuel injectors for leaks be a part of some maintenance schedule?
I can't imagine we just rely on our smell of fuel as the manner to detect the eventual failing of fuel injector o-rings. what if some people can't smell shet?
Old 08-29-2016, 09:18 PM
Soviet's Avatar
Originally Posted by Soviet' timestamp='1472167803' post='24047958
[quote name='jyeung528' timestamp='1472167401' post='24047953']
[/quote]
Every 15k miles - "Inspect fuel lines and connections"
Old 09-09-2016, 11:20 PM
jyeung528's Avatar
Originally Posted by jyeung528' timestamp='1472533974' post='24050777
[quote name='Soviet' timestamp='1472167803' post='24047958']
[/quote]
[/quote]
thanks, but how do you inspect for a leak? sniffing it with your nose?
Old 09-10-2016, 06:11 AM
Slowcrash_101's Avatar
That's the easiest give away, probably much more safe than using a pilot light You can also measure fuel pressure but that's a bit trickier, you either need to tap the fuel rail or get a special adapter to put in place of the fuel pulsation damper in order to connect a fuel pressure gauge. It's almost impossible to not know you have a fuel leak, the smell is so strong that if you can't Toucan Sam your way to the problem you have no sense of smell.
Quick Reply: Gas leak
