Gargling noise from rear end?
guesses, and guesses only here:
1. Check that all your CV boots are in-tact. The 'squirt' noise could be grease squeezing out of a crack or hole, and it's so viscous that it wouldn't immediately drip but rather sling off as you drive.
2. Is there an overflow vent for the diff somewhere? I don't know, and I'm leaving it to the orignal OP to do the research. However the OP said they changed the diff fluid recently, and if it is slightly over-filled, perhaps it's simple pressure relief we're hearing. It wouldn't have to be so much that measurable fluid would come out and drip.
Originally Posted by Chris Stack,Aug 3 2009, 06:38 AM
I actually recently replaced the two rear diff mounts, so I don't think it's that. You might be seeing a lot of movement because the whole car was on jackstands for the videos, so there wouldn't be any opposing force.
I think my next step is to try changing the diff fluid back to Honda OEM. Is there any scientific amount that needs to go in there? I just added fluid until it trickled out, like in the DIY sticky, but are there specifics like car should be in gear, not in gear, etc?
![biggrin.gif](https://www.s2ki.com/forums/images/smilies/biggrin.gif)
My next step will probably be to replace the fluid again, this time with Honda OEM stuff.
Originally Posted by Chris Stack,Aug 4 2009, 06:00 AM
Used Mobile 1 75w90. And only replaced the upper crush washer, forgot to buy lower. But there are no signs of leaks.
BlueS2000Boy
01-09-2006 07:55 AM
