Garage Queens - Fluid change interval?
I finished a rebuild project last year that's become my DD and haven't driven Stella more than 2000 miles since. I'm overdue on fluid changes by time (years/months) but still have mileage remaining.
Is it important to stick to the manuals 6 month and 1 year intervals as much as the mileage? Or am I okay waiting?
First time having a garage queen car. Thanks
Ps. I used the search already
You'll be OK waiting.
Once a year for the oil/filter will be fine, and even then, likely overkill.
I'd do the diff/tranny/coolant based on mileage.
You can get an oil sample test from Blackstone, but anything else is pure opinion and not science.
I do less than 3k miles per year, I do the oil change one per year in the fall before it goes into winter storage, I do diff fluid and tranny fluid changes every 2 years, still overkill but it gives me peace of mind.
The military gave up on mileage based service long ago - and those guys are dinosaurs about modernization (anybody still jumping with T-10s?). They have since switched to analysis based service by doing UOA (used oil analysis).
Remember, documentation for service was written to cover their ass (manufacturers) from excessive warranty claims.
So take for example the typical car. Most probably have a 5 year/40k mile bumper to bumper warranty. Most manufacturers want you to change oil every 10k miles or annually, right?
So what they are saying in english (assuming these conditions) is that if you follow our recommended guidelines and change your oil every 10,000 miles with our oil and our filter, we can reasonably guarantee that your car will last 5 years or 40,000 miles, which ever comes first. I'm going to take a wild ass guess, but they probably want 95% of cars @ this mark to be trouble free.
But wait, they also have to make sure that this service interval, 10k miles or annual oil change, also hedges against people who buy extended warranties, say 7yr/100k. Now not everyone gets an extended warranty so they don't need a high percentage of cars to make it past the 7yr/100k mark. They don't need 95% of cars to make it to this milestone, perhaps 85% will sufficiently make the bean counters happy.
My answer to you, is change your fluid and turn gears as often as you can or your wallet can afford. Metals like being lubricated.
IMHO, this is the key. Try to make sure all parts (esp top end) is lubricated, between starts after long off-times. Prolly most wear in Garage Queens are in first startup in months or years --- when all of the oil is in the pan.
But thank you for the advice. I'll look in to the oil analysis kits and go from there
Honda maintenance schedule is in the pre-2006 owners manuals and available on line. Use the 2005 schedule for 2006 and later if you're curious, otherwise the Maintenance Minder will handle it for you.
"Fluids" (assuming you didn't just mean "lubricants") like the hydraulics and coolants are time, not mileage, based and should be changed per the schedules.
-- Chuck
-- Chuck
I was going to still do coolant, brakes, and clutch. Thanks for the reassurance.
I'd pour a little oil over the valve train and hand crank or turn the motor over with starter, only. Try to be sure red oil pressure idiot light is out --- before starting the engine.
Sometimes being this anal just isn't worth the trouble.
Try this instead: Enjoy the car as often as you can, and worry less...
SaintS2000
07-03-2018 07:45 AM
Destiny2002
02-09-2004 12:41 PM
