Garage parked for 4 months now will not start
#21
The guys are being pretty rough on you. When you don't know a lot about cars you are at the mercy of the shop. That's why it's good to find an honest mechanic (and difficult). The good thing is your car is back in business.
I would suggest that the next time you need repairs that you ask for the return of the old parts that they replace. That lets them know that you are paying attention to the work that they are doing. Also, as mentioned, those extra services like "fuel injection cleaning" are often up-sells to extract more money from you. If you have a clogged injector, and the procedure is done correctly, it can be helpful. It's just hard to know when it's necessary. You could ask them to show you why they think it is necessary. It's ok to ask questions.
Have fun
Mike M.
Have fun
Mike M.
#22
A bad cam sensor will DEFINITELY do it. I feel like if you would have pulled the codes you could have seen one for camshaft position. Replaced it, bam. But its fixed nonetheless.
Fuel treatment service? ONLY products I would recommend as a tech is the BG products like 44K, and my all time favorite ONLY IF YOU HAVE A TEST PIPE, Seafoam. Many people come in for a P0420 code after seafoam which means you toasted your catalytic converter. I think the perfect combo is the gas mix seafoam, and the aeresol spray with the U-shaped straw used in the throttle body.
I ran the aerosol spray seafoam on my S and after, I looked inside my intake manifold with a flash light and it was spotless! Covered in black oil, soot, gunk before.
#23
Have fun
Mike M.
Have fun
Mike M.
#24
I finally got the car back today.
What was wrong - CamShaft Position Sensor
The shop said this is why the car didnt start because the sensor was bad and that it prevented the car from starting
They also recommended I get a Fuel Injection service - they said this because that this was gunky when they where locating the problem also said it would prevent the other sensor from going out
All in are the total cost was $408.52 at the shop and $125.00 tow for a total of $533.52
Im just glad its all fixed
As for the suggestions, I don't know anything about cars. I like s2ki for the wealth of knowledge on the s2000
I am trying to learn and be a more doi type person but I dont trust myself and think i would make the problem worse
Therefore I trust my shop in Pasadena
Did they give you back the old sensor?? They are supposed to if they said they changed it....
#25
BTW, the S2000 has TWO TDC sensors. They are both identical. One is located on top, at the rear of the valve cover and the other one is on the side, at the rear of the valve cover. There are many examples posted on this forum that indicate the engine WILL run with one bad one. It may or may not start, depending on how well maintained the engine is and when it does run, it runs poorly, but it will run.
#26
#27
Try swapping the fuel pump relay in the under dash fuse box with one of the similar ones in the same fuse box. I've seen them go open circuit when they have been left for a long time. I think its burnt deposits on the contacts going fuzzy from humidity during storage. If you open up the relay you can drag some wet and dry between the contacts and it will start working again.
