FYI - Failed Denso Irridium Spark Plugs
Old 10-03-2005, 08:46 AM
nibble's Avatar
thanks,
Old 10-03-2005, 08:31 PM
BENJMNS's Avatar
so anyone have a link to a vendor that sells the right NGKs? i have the densos now following the advice of others here, but sounds like some problems are creeping up... i don'wa tn to take the risk.
Old 10-03-2005, 09:01 PM
GoFaassttt's Avatar
^ the best price I have found for NGK plugs is at
www.rockauto.com
Old 10-04-2005, 03:19 AM
CoralDoc's Avatar
Just some more data to consider:
aRrakis reported exactly the same failure in his IK22 Denso Iridium plugs in xviper's spark plug thread. Others in that thread reported engine misfires even on NA engines.
Old 10-04-2005, 06:44 AM
xviper's Avatar
www.rockauto.com
That link is incomplete and doesn't work by itself. You can still just type in the URL to get to that site. However, after doing a short search, it was not easy to find spark plugs in there.
Here is a better place:
http://www.sparkplugs.com/results_cross.as...=7173&x=42&y=12
How much cheaper do you want them?
Just ordered 4 sets.
Old 10-04-2005, 07:31 AM
adam_gipson's Avatar
What is the NGK equivalent of the IK27?
Old 10-04-2005, 09:34 AM
GoFaassttt's Avatar
[QUOTE=xviper,Oct 4 2005, 06:44 AM]
Old 10-04-2005, 12:40 PM
FF2Skip's Avatar
You can get NGK 7173's locally at Advanced Auto Parts. Cost is about $1.89/plug if I remember correctly.
I did have a negative electrode break off one of these plugs. I won't speculate as to how/why it happened. I think it was a combination of things. I will continue to use them, however, I will NEVER let anyone install them other than myself.
Old 10-04-2005, 01:25 PM
nibble's Avatar
Skip, as I was researching through NGK and other site, I found that 7173 is 1 step colder than our stock. according to their web site, you should increase as per 75 to 100 hp increase. If I remember correctly, I heard that you were putting down 390 hp at the wheel. If so, I believe using 2 step colder spark plug would've been better.
NGK for OEM 2000
part# PFR7G-11S, Stock# 7772. Platinum tip, 14mm, 3/4" reach, 5/8" Hex. heat Rating: 7, Gap 1.1mm (.044")
NGK for 1step colder
part# R5672A-8, Stock# 7173. 14mm, 3/4" reach, 5/8" hex, heat Rating: 8
NGK for 2step colder
part# R5672A-9, Stock# 7405. 14mm, 3/4" reach, 5/8" hex, heat Rating: 9
So, I think it would've been appropriate for you to go with 7405 instead of 7173. I hope someone else can confirm the information I have.
cheers,
Old 10-04-2005, 01:34 PM
FF2Skip's Avatar
Thanks, Paul! I like your number that you gave me. I was only up to 371.
Now @ 0.
Perhaps for daily cruising I could use the 7173's and then switch to the 7405's for autox/track. I guess I'd need to tune for that as well.
Quick Reply: FYI - Failed Denso Irridium Spark Plugs
