FYI: Engine and Tranny weight
Old 04-28-2004, 08:19 AM
Administrator
krazik's Avatar
Default FYI: Engine and Tranny weight
Since I have them both out and attached together still I put my engine and tranny on my Long Acre scales to see what they weighed. Engine had no water or oil, but tranny still had fluid in it.
I put 1 scale under the oil pan and the other under the tranny mount (back of tranny)
Total Weight was 400lbs, 273lbs on the front scale and 127lbs on the back one (under tranny mount)
Just FYI.
Old 04-28-2004, 08:31 AM
Asura's Avatar
Hmm...interesting.
Old 04-28-2004, 09:08 AM
Administrator
krazik's Avatar
weight does include hoses and wire harness.
no ac compressor tho.
Old 04-28-2004, 12:55 PM
Administrator
krazik's Avatar
so with out the engine and tranny, my car is now under 2000 lbs.
-Ry
Old 04-28-2004, 02:45 PM
red02s2k's Avatar
I wonder how acierate that is
Old 04-28-2004, 02:53 PM
Administrator
krazik's Avatar
You saw I used longacre scales right? Its very accurate.
Old 04-28-2004, 04:49 PM
hans's Avatar
Does the 400 lbs. include the exhaust header?
Old 04-28-2004, 05:37 PM
Asura's Avatar
No.
Old 08-15-2009, 07:22 PM
Grant B's Avatar
Ah, thanks for this. I bought a NA Miata with a F20C in it, and always wondered if the motor weighed more or less than a Miata's 1.8L iron block. Looks like its a bit heavier.
Is this with a stock weight clutch/flywheel assembly?
Old 08-15-2009, 08:40 PM
energetic's Avatar
Back from 2004. Not bad.
Quick Reply: FYI: Engine and Tranny weight
