Fumoto oil valve installation query
can anybody give me some advice?Do you use the crush washer and the oil valve washer or discard one or the other when installing the drain valve. TIA
In order to fit the S2000, the Fumoto valve needs to be used with an adapter. I installed the adapter and valve using only the fiber gaskets supplied with the valve. Be very careful not to over-torque the valve as it is made of brass and is not as strong as the steel drain plug bolt.
RydinRuff
27
12-06-2008 11:29 AM
