Fumoto drain valve busted
Old 06-03-2004, 06:13 AM
jlvtx1800's Avatar
Default Fumoto drain valve busted
I did my first oil change last night and all went very smooth except when it was time to install my Fumoto drain valve. I put on the adapter screwed it on. The problem was the valve lever was sticking down, which is bad. I unscrewed it and tried starting it several other points but it always ended up at the same spot. Here is where I got stupid. I took the adapter washer off and did the whole thing over and this time it ended up perfect. I though to my self I will make a mark, put the washer back on and tighten it back up till they match up (not a good idea). I did this, and screw sheered right off . I don
Old 06-03-2004, 06:17 AM
Ztec's Avatar
I left mine where it tightened up and it is in the down position - I have an Xbrace that protects it and I have had no problems! sorry to hear of your misfortune.
Old 06-03-2004, 06:19 AM
SolReborn's Avatar
I just bought one too, but am waiting for my next oil change to install it. I was reading the instructions, and it does say to not torque it too much b/c it is made of softer brass...
Sorry to hear about your problem though...
Old 06-03-2004, 06:39 AM
Former Sponsor
Gernby's Avatar
Mine is exactly like nzaizar's.
Old 06-03-2004, 06:49 AM
MacGyver's Avatar
Mine points towards the bottom, and I warned of tightening too much in a previous thread (same thing happened to mine when some friends were installing it). This is soft brass, NOT steel...tighten by hand only (no torque wrenches), and snug it up only, don't lean into it.
Old 06-03-2004, 09:18 AM
SolReborn's Avatar
Does everyone's valve point downwards?
Old 06-03-2004, 09:34 AM
Hockey's Avatar
Mine goes to the left!
Old 06-03-2004, 09:47 AM
usace's Avatar
mine does. It kind of bothered me at first, but I've had it in for 15k miles with no problems. I wanted to tighten it some more so it would face a different direction, but remembered reading about others who had problems with it breaking.
Old 06-03-2004, 09:48 AM
hatchimon's Avatar
mine is off to the left slightly....lol. Im being serious thou.
Old 06-03-2004, 09:55 AM
SC_Highlander's Avatar
It took a few tries, if I remember, but mine is installed with the valve lever up and slightly toward the front of the car. I can reach down between the engine and the heat shield to open it!
Quick Reply: Fumoto drain valve busted
