Fuel Pump Help
Fuel Pump Help
So my S2000 fuel pump went out and i really need to know how to change the pump....Does anyone know how to do this or know about a thread?
thnx
thnx
i have it in the s2k pdf service manual, it's also in the comptech supercharger pdf diy, i can't email the service manual pdf 'cause it's too large but i can email the supercharger pdf, it has the page from the service manual posted in there,
basically you take out the top tray, located behind the seats, it's attached in by tabs and in the aft portion there are two nuts that have to be removed, the tray has to be removed to access the fuel pump cover.
in the trunk you need to remove the forward carpet coverings, the fuel pump is on the left, there is a cover that has to be removed, then underneath you need to remove two tubes and remove the bolts, i had to use a mirror to see to remove them, then you yank out the fuel pump.
the fuel pump is in the assembly, you'll have to remove the filter on the bottom and detach the electrical connector to remove the fuel pump. then you reverse install and check for leaks.
this is kind of hard to describe, especially when i did it like a year ago, this is one of those examples where a picture is worth a thousand words. maybe you have a localite that could do this with you and walk you through it?
found a install guide for the fuel pump...
http://www.driftopia.com/2008/01/05/honda-...all-walbro-255/
