Fuel pump help
Fuel pump help
Ok so I've been having random misfire codes show and my cars been bogging so I changed the spark plugs nd tested the coils, they were ok, so my next thought was injectors or pump and I jus changed my pump and it's running really smooth now, but my fuel gauge says my tanks empty when I jus filled it, any suggestions on how to fix it?
there has to be something wrong with the fuel pump install. either you forgot to plug it back in, some of the wiring cracked, or the floater is being blocked by the filter sock. i would just uninstall and check it, then reinstall.
