Fuel Pressure Regulator, does it help?
Old 02-28-2003, 09:48 AM
Former Sponsor
Gernby's Avatar
A stock S2K runs rich, so the V-AFC is able to increase power by tricking the ECU into providing less fuel. An FPR would really only be usefull for increasing fuel. They would be working against each other (on a stock setup). FI setups require more fuel, so they sometimes use an FPR to increase flow BEYOND what they really need, then use a V-AFC to take the extra back out (fine tune).
Old 02-28-2003, 02:16 PM
Former Sponsor
Shadow_S2K's Avatar
What if i just have a CAI/ HEADER/ EXHAUST? Would i need the FPR then? Thanks
Old 02-28-2003, 02:40 PM
Former Sponsor
Gernby's Avatar
No. Unless you install a turbo or super charger, you already have more fuel than you need.
Old 02-28-2003, 02:48 PM
TepEvan's Avatar
So in general, a V-AFC is a good addition to any s2k it sounds, because if you're stock you're running too rich already.
Is this a correct statement?
Old 02-28-2003, 02:58 PM
Former Sponsor
Shadow_S2K's Avatar
I ask a car performance shop before, and they told me that i would gain MORE hp if i had the FPR then if i didn't....thats not true? So i shouldn't waste all that money to get the FPR and get it installed hu?
Old 02-28-2003, 03:52 PM
Stale_Hotdog's Avatar
Of course they're going to say that. They are in the business of making money. They want to sell you that Fuel pressure regulator.
Old 03-02-2003, 10:36 AM
Wildncrazy's Avatar
From the looks of things the emanage would do a better job of tuning than the VAFC and it appears to be easier to use.
It also can control the timing.
Now you would be set should you get the bug to add boost later.
Old 03-03-2003, 01:04 AM
ExOdy's Avatar
Not worth the money from what you get out of it.
Old 03-03-2003, 04:41 PM
Former Sponsor
Shadow_S2K's Avatar
Thanks for your input hehe
Old 03-04-2003, 03:56 AM
Schatten's Avatar
agreed - an FPR alone on this car won't do much at all. The ECU will still do everything and that's tunable by a VAFC or an ECU replacement.
But on cars like a Mustang an FPR - yes, it will increase performance. This car is not straight forward with which gains will gain the most power, so common speed shops aren't going to know what is right for this car, IMO.
Quick Reply: Fuel Pressure Regulator, does it help?
