Which fuel pressure gauge do you use?
I'm referring to the under-the-hood type, not the remote gauges that you mount on your dash. Anything in particular I should look for when buying? I'm having issues w/ my 200K mile Accord and I'd like to get some before & after readings on the fuel pressure when I replace the fuel filter.
BTW... does anyone know if Honda uses a standard fitting size for the service ports on the fuel rails? I read on an Accord forum that they use 12 x 1.25mm. Anyone know if this will be the same on the S2000, or should I be looking for multiple metric fittings?
